21 Dezember, 2025, 02:35:38
  • Heute online: 163
Gäste: 91
Gesamt: 91
91 Gäste, 0 Mitglieder
Anleitung : Impulssteuerung für Fensterheber.
Begonnen von kaween, 06 Januar, 2013, 15:09:44
lodia
Sorry. English translate.
Could you add photos with relay + diode part pcb? Thanks.
Have only pictures from previous setup. But is very similar to actual setup.
lodia
11 Juni, 2017, 16:53:35 #77 Letzte Bearbeitung: 11 Juni, 2017, 17:45:20 von lodia
Thanks!
i can't understand relay platine scheme and can't see solder  at photos. I found same relays at eBay. Could you add simple scheme using that sip-1a12?
I see at scheme that 2 relays have pins 1 and 3, a5 and 6 all conected, but photo shows one relay inverted or without logo (?)
11 Juni, 2017, 18:06:07 #78 Letzte Bearbeitung: 11 Juni, 2017, 18:08:34 von NinnJou
Doesn't matter how to connect relay.
Example:
Pin #1 and #7 will be closed if 12V and GND is on #3 and #5 (or #5 and #3).
How you connect 12V and GND to pin #3 and 5 doesn't matter. Only make sure the diode is connected like this:
Anode is connected to GND pin (#3 or 5) from relay
Cathode is connected to 12V pin (#5 or 3) from relay
How this diode work and need to be connected, you can see here as well:
https://en.wikipedia.org/wiki/Flyback_diode
lodia
11 Juni, 2017, 18:29:40 #79 Letzte Bearbeitung: 11 Juni, 2017, 18:49:36 von lodia
Are 1a-12v relay and small diodes enough? I'll use with >40°C sometimes.
Could i install without retire whole door panel?
A simple Diode 1N4148 or similar is enough. No need special stuff.
The relay did not switch the motor it "simulate" a simple switch, that switch +12V as "Up/down" for the PSA box.
Because Renault/Dacia switch the GND signal and not +12V.
You can cut the cables without removing door panel, but you have very small space for it.
But I am not sure if there is enough space below the switches for that box with cables...
lodia
I have dokker, with smaller button panel. I´ll try to do it.
https://www.youtube.com/watch?v=BOvkvDqj6A0
Thanks and sorry again for use english translation!!
no idea. find it out  ;)
Nissan stuff often fit on Renault and Dacia - same company...
lodia
prototype. Nissan connectors plug&play. Working!!
